Like the title implies I'm trying to convert video for my ipod touch. I already know that you can convert the video then mux the srt. However, I'd like to keep the font & effects that come with ASS/SSA subs. Is there anyway I can mux ASS/SSA with the MP4 (m4v) container? I know I can just hardsub them but that would take way too much time.
Also, I've looked into using RipBot264 but it tells me that I need to install FFDshow rev 3100 or later. I already have CCCP installed which came with FFDshow so if I were to download rev 3100 would it conflict or something?
Thanks in advance
I doubt the iPod supports .ass subtitles, muxed or otherwise. You can try converting the MKVs directly to iPod video formats using AVIDemux, and adding the .ass subs to the video for hardsubbing with the ASS/SSA hardsub filter (but you'll need to have the subs as an external file).
The iPod probably supports only plain-text subs... something like the .srt format.If cameras add ten pounds, why would people want to eat them? -
Have you tried xvid4psp yet? this is not only for psp as you can do just about anything with it and you can hardcode subs so you'll beable to play them on your ipod i even think there is even a default i podmp4 setting.
I recommend you try xvid4psp 4114 version because on newer versions you have to extract the subs before using other software then import and recode. You can download xvid4psp via the link in this page and then select old versions and download, after you've installed and running just open the mkv and go from there.
hope this is of help -
Originally Posted by spunge85
Please help me about converting avi (xvid) to MP4 (Ipod touch 4g)
By jolo in forum Video ConversionReplies: 2Last Post: 4th Jul 2011, 02:38 -
iPod touch video with switchable subtitles
By txporter in forum SubtitleReplies: 5Last Post: 13th Jan 2011, 15:35 -
MKV with .ass or .ssa subs into mp4 for ipod
By lilly1991 in forum Newbie / General discussionsReplies: 0Last Post: 27th Jul 2010, 09:57 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 14:11 -
MKV with subtitles and fonts attached to ipod touch format?
By EwanG in forum Video ConversionReplies: 4Last Post: 19th Mar 2009, 16:27
